new tire problems
TJ2012HD
Well first let me start by introducing myself. My name is Tim and im sporting a 2012 2500 slt crew with the 5.7, Its my dailey if im not on the bike. I own several trailers including a 30 ft 5th wheel.
I come looking for some help im having with my truck. Its all stock with the exception of a wheel and tire combo i just bought.
Here is where i need some help. the set up is the vision warrior 375's in stock back spacing and rim size of 17". the tires i went with are the hankook dynapro atm also in the stock size. I also have the "install kit".
As soon as i pulled out of the garage i thought it felt funny, Like i had underinflated tires on all four corners. the tpms said 70 psi +/- a lb or so each wheel. I put the camper on the back and holy crap it was just scary. I felt like i was chasing the damn thing all over the road. emailed the place i got them from they told me to take them up to 80 psi. I did with no difference.
Has anyone had an issue like this and any ideas as to what i should do?
thanks to all in advance,
Tim
Andy578
Ontario, Canada
2014 Outdoorsman
never heard of that happening. are they flexing a lot or do they look normal? also did you balance them?
2011 Ram 1500
I would say check for balancing and make sure they are on tight.. Maybe realignment is off too?
joRTe
maybe the type of the tire.
T
TJ2012HD
yup they were balanced, alignment was dead straight before i installed them. I torqed them to 110, retorqed after the test drive. I had someone tell me the tread is really soft on these tires and that could be what im feeling.....opinons on that:crazy:
T
TJ2012HD
No i ordered them as a package from discount tire direct. They have been awesome trying to help out with my situation.
T
TJ2012HD
Lt 10 ply 265 70 r 17 factory size
toofart
QC Canada
Hemi 8 spd
This is not likely your problem, but 110 ft. lbs is not enough for a truck wheel. The 1500 calls for 130 ft lbs.
T
TJ2012HD
Well discount tire is going to replace the tires at no cost! Now i need to choose from a few options, which are the Falcon wild peak HT, the Hankook Dynapro HT, or their general Tire HTS. any opinions from all you guys would be great.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
I had a similar issue once with tires on a ford escort stationwagon.
It turned out that the tread pattern on the tires was perfectly aligned/sized with the linear grooves on/in the highway I drove such that the tread blocks tried to follow the grooves, and it made it feel like you were driving on a layer of ice.
Sears (where I got them from) replaced them with a different tread pattern for free. Problem went away.
14hemiexpress
6.4l
Hancock make great tires in the sport/performance world I haven't herd much in the Heavyduty line up, I have seen many good reviews about the general tires honestly it's a toss up.
GrandpaDon
