I'm considering a 2013 Ram 2500 Laramie Crew Cab 4x4 with 87000 km Diesel engine. I'm in the market because I'll be towing a travel trailer weighing 9000lbs. After my test drive I noticed the front end was a bit loose and not as smooth as I thought it would be. Without anything to compare to, the Dealer suggested I compare to a similar 2016 model. The 2016 was much better. When I pointed this out to the dealer they did say that the 2013 would go through a series of inspections before being sold and any issues would be fixed. I'm a bit leary that the issue (if there is any) would be something they would address.
Any suggestions on what I should look for? Maybe a front end alignment will improve the handling? Any feedback would be appreciated. Thanks!
