Nitro 4:11 gears
98blackbeauty
Lynchburg, Tennessee
Been searching for new gears for my 98 dodge 1500 4x4.. I found a Nitro package front and rear with all shims, bearings, and crush sleeves.. Its about half of what I was looking at for Yukons. Was wondering if anyone had anything to say. Good, bad or indifferent just looking on some insight for the long haul thanks
Ram 1500 Gear Package 4.11 Ratio
BBartow
New Port Richey, Florida
5.9L Magnum
$720 vs $925. Good deal I suppose.
98blackbeauty
98blackbeauty
BB what kind of locker do you have? Im currently reviewing the Detroit/Eaton Truetrac. It seems to be a good one, Im just looking for one where if I gotta put her to the floor im either coming out or callin the tow truck haha
Merc225hp
NA
truck
gas
I would get that package good deal in my op. Truetracs are a very good lsd for a DD.
BBartow
5.9L Magnum
I have the factory LSD
98blackbeauty
98blackbeauty
ok thanks guys, and after reading alot of gear changes on here, 4:11's and 4:56's cost the same in the package, I think im just gonna go with 4:56's.. I do alot of highway driving but im thinking Ill still only pull bout 2200-2400 running 70 and thats fine by me, cant get worse than my already 11.5 on the open highway
Merc225hp
NA
truck
gas
Haha wanna bet lol.
Picking gear ratios is a interesting thing to do, there were things I liked about using 4.56 and things I did not like. I am in a 4.10 ratio and 315/75r16 tire and to me were I drive/speed limits and for what I do with my truck they are my pick for now. I have also ran 3.92 ratio with the same tire size, the 4.10 ratio is just a bit better than the 3.92 ratio.
98blackbeauty
98blackbeauty
hahah oh ok appreciate it.. so i dont do tons of wheeling but do get my kicks off often.. I got the 5.2 with 5spd. recommend 4.56 or 4.11
Merc225hp
NA
truck
gas
I take it the motor is stock and the truck has a lift = 4.56
98blackbeauty
98blackbeauty
yeah stock motor and 3" body.. when you ran 4:56 did you have to buy a different front carrier for the 44? cant find a clear answer on it
Merc225hp
NA
truck
gas
For the rear no you don't need a new carrier (the 9.25 carrier has no ratio breakpoint), or bearings if your's are in good shape. You will have to trim the heel of one tooth if you use the factory LSD as the cross-pin will not fit. This in no way hurts or bothers the gear in anyway shape or form. For the front you can get thick cut gears or you get reg gear's and a new carrier.
98blackbeauty
98blackbeauty
ok cool.. if i get a locker for the rear thats my carrier right? nvr done a locker change only a basic rebuild on rear.. if thats the case then ill goahead and order the truetrac and 4:56 gr
Merc225hp
NA
truck
gas
Place your order bud, one in the same.
98blackbeauty
98blackbeauty
ok bud i appreciate the time to walk me thru all this. Once I get back from this deployment I will get everything ordered and me, my dad, and grand father will get it all put in.. Once again i appreciate it
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Yup, 4.56 = stock ratio for 35s compared to 3.55s on 265s.
MoparMagic'00
Arkansas
5.2 Magnum
sorry to hijack thread but has anyone ran a 4.56 with a 33/12.5/15 or a 285/75/16? Im wanting to go taller than i am already (stock height) and but i need to rebuild rearends first.. so id rather get gears while im already there..
oxymoron29
1997 Dodge Ram Sport
5.2L
It's not, this gets thrown around way too much. Do the math, a 3.95 gear ratio with 35's gets you revving where you would be with stock gears and tires. Thus, 4.10 would be the closest, best option if one wants to maintain close to factory revs on the highway without undergearing with a 3.92 ratio. 4.56 will make you rev higher than stock but may be a good option for those looking for better acceleration and towing capability.
KAKA
