OEM fluid alternates
Fire1332
United states
Looking for insight on alternate fluids that ones have used other than the mopar for the transmission and transfer case. Was looking into amsoil, but want to be sure it’s safe. I have the 48-11 TC. Also wondering about the rear diff. Most fluids I’ve seen says it has limited slip additives already. If it’s stated on bottle is the mopar additives still required.
2021 Ram 1500 3.6 4x4
There's nothing wrong with using Amsoil, it's usually one of the more pricier options for automotive lubricants. Lubricant brands are an individual preference, there entire threads on this forum debating all of them. About the only mainly agreed upon item is use full synthetic lubricants.
As for the rear axle lube, if it states it already has the friction modifiers then the Mopar stuff usually isn't needed.
Burla
Army
2010 Hemi Reg Cab 4x4
The zf8 has issues, it benefits from frequent changes but it is a damn yarn of a fluid change, as in it is a process and even when complete it is a two video process just to check the level. Furthermore, it doesn't like high quality fluids that may extend the interval a bit. And then there is this, the zf8 fluid which was supposed to be higher quality is nothing more then a maxlife type fluid with a different color, it's all on the stat sheet. It is a risk to use a high quality fluids in the zf8, the risk is they tend to be too slippery for this application. It only works some of the time wouldn't move the needle for me when considering what fluid to use. The safe moves, maxlife multi vehicle (different color though) , zf8 lifegard, or OEM. learn to embrace the suck and use maxlife and change it often, like under 50k miles would be my thought on it. it could be worse, some fords you need to drop the trans just to change the fluid, no joke.
I would use Amsoil in diffs and t case.
