No Audible Chimes
Ralph Mauro
Otonabee On
Has anyone come across NO audible signal click, seat belt warning, key in ignition, or door ajar?
Ralph Mauro
Ralph Mauro
Otonabee On
2016 Crew Cab 4x4 would be helpful to hear signals flashing.
Fuses check out to be good
Had an OEM trailer brake controller installed and programmed. Everything else is original 48,000 km.
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
ignore this, see next post
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
From my Alldatadiy account for my 2012
"The instrument cluster chime warning system circuits and components cannot be adjusted or repaired. If the CCN circuitry or the on-board transducer are damaged or inoperative, the complete unit must be replaced."
Ralph Mauro
Ralph Mauro
Otonabee On
No codes not battery it's been like that for almost a year. Everything works good just no sounds signal is my biggest concern Thanks
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
I corrected myself. See my other post. The book says the chime system is integrated into the cluster and cant be repaired. You have to replace the whole cluster to fix it
Simpleman
New jersey
If mine didn't work I wouldn't care I hate hearing all that crap
WadXpress
HEMI
Mine doesn’t make noise either. I wonder if it’s from when I upgraded clusters. I prefer it making no noise anyway
Ralph Mauro
Ralph Mauro
Otonabee On
Mines original. Did you loose everything as well? Seat belt key in ignition, signal, door ajar.
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
on a completely unrelated topic,years ago there was a procedure with the seatbelt where you could disable the seatbelt chime/notification on the 4th gens,anyone know if it works on the new trucks and if it does,how to do it ? i can't remember the procedure,it's been a long time.
Ralph Mauro
Ralph Mauro
Otonabee On
I did try that procedure with the seat belt it did not work for this model.
Thanks for your reply
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
I used alphaOBD to turn off my belt chime. My previous cars you could just open the belt receptor and jump the switch inside. Its alot less involved now :)
Ralph Mauro
Ralph Mauro
Otonabee On
My biggest concern was that I can't hear the signal clicking when their on or if their on.
