No brake lights
Steveinar
Just purchased a 1998 Ram 4x4. When I turn on the left turn signal, the brake lights do not work. When I turn on the right signal there is no problem with the brake lights. Just driving normally the brake lights work fine. Suggestions?
dapepper9
Iowa/Nebraska Border
5.9L V8
Check bulb, for broken wires, and if you have a trailer harness unplug that and check the connections. The harnesses can get water in em and corrode
