NO BURNOUTS! WTH! lol
MFerrier
Alright guys, could easily do a brake stand with my truck when I got it, could light them up off the line and now it feels gutless, slow throttle response no idea what's going on! anybody have this issue? 2007 dodge ram 1500 hemi 4x4
M
MFerrier
Also I got the truck about 6 months ago
Johnnymac2k6
Ohio
2007 Ram 1500
The truck learned that you wail on it at every stop sign, and decided to stop you from doing it :)
BrianandChrissy
Buffalo NY
2016 big horn crew cab
5.7 hemi, vararam CAI
Id check the windshield washer reservoir... it may be carbon fouled, causing a misfire...*****
sent from galaxy S7 edge using tapatalk
Buckfat
SW FL
Recalibrate your throttle. If you drive like a granny for a couple weeks it learns your habits. If you don't know about throttle recalibration, look it up.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
This sounds like the member that came asking why his transmission burnt up and then proceeded to explain that he did multiple burnouts, mashed off the the line, etc. It's no wonder the trans was toast... I'll just leave it at this - it's 6K# truck, 4WD and all, it's not made to burn the tires off, if you wanna melt tires then put some 30" tires on and have fun.
Lil_Ram
Power tech 3.7L
No I do believe that it's the flux capacitor. You have to make sure it works if not you'll never achieve a true burnout. And Tray I thought it was 30hp with a weight reduction to boot
Tray Burge
On the porch
Lil_Ram, yes, I forgot to mention that. If you run your camber all the way out so your front wheels are crooked that also helps when your trying to do burn-outs!
Lil_Ram
Power tech 3.7L
Don't forget the 11.5" tires on 22x14s
usaf2006
North Carolina
One word. Stacks. Nothing else on a gasser provide smore bang for your buck hp.
