hunterdan
- May 7, 2018
- 1,157
- 1,517
- Location
- SE PA
- 2019 classic
- 5.7 Hemi
My 19 classic hemi has been puzzling me for a while. The thing idles smooth and fairly quiet. There's no noises that concern me. The fuel mileage has been abysmal, especially for stock sized tires. I'm currently sitting at 106k miles. Original plugs. Like I said, idles smooth as glass. 3.21 gears. The thing feels like a dog off the line, until 3500 rpm then it rips. The problem is, when cruising on the highway or any road for that matter. When your cruising at 1500-2000 rpm, if I hit even the slightest of inclines, it bigs down and has to downshift. It can't hold the gear, it requires a lot of throttle input. My older Silverado with the 4.8 seemed to have better low end and didn't struggle like this. I don't believe it was always like this.
Now, yes it's due for spark plugs. But, I can't believe they'll make a huge difference in performance if I'm not misfiring. The tires are stock size, on a small level. I actually went back to a stock sized tire trying to see if that would fix the issue. It clearly did not. I know the 3.21 gears don't help, but again, stock sized tires 275/60r20.
Gummed up intake? Bad O2 sensors? SRV not actuating fully? I don't expect this thing to get 25 mpg on the highway, but I should be getting better than 14 on mostly highway trips. I know my front bumper isn't helping, but again this issue has persisted before the bumper was installed.
I'll probably pull the throttle body off this weekend, clean it and try and get a good intake cleaner and let it soak for a few hours. At least that's where I plan to start before digging deeper and going more intrusive. I know it could use plugs, but again they might gain me 1-1.5 mpg, if that. And if I'm going to be pulling things and cleaning, I'd rather do all the cleaning first, then the plugs.
Where would you start? What would you look into? I have an OBD2 scanner, what would you check?
