Auggie1956
- Nov 21, 2014
- 15
- 0
- 1999
- 5.9 Diesel
Pretty simple yes. The starter cranks with a bump switch leads, connected to the battery pole, and the ignition switch pole on the starter it self. The batteries are in good shape as the truck started and ran good, then one day nothing. The head lights stay nice and bright when the key is turned. I did a test light check in the neutral safety switch plug, and one out side wire on the plug that hot all the time, and the other two nothing, no matter the position of the key. I have tried moving the shift lever with the key in start position and nothing. Any suggestion ? Is there a starter circuit schematic available here on the sight ?
Many Thanks.....
Many Thanks.....
