No power without key
Wyatt143
Az
5.9 Magnum
I got a 2002 ram 1500 2wd quad cab, I replaced the hood but didn’t want the wiring so I cut it without disconnecting the battery, the radio resets every time I start, no obd power without the key, no door lock without key. I checked fuse 51 and it tested good. Changed anyways no luck, is there a relay on the under hood harness I didn’t see? Not sure if anyone has had the same issue but any input would be great.
Timsdually
Jersey
Cummins
Try posting this in the appropriate generation (year) trucks. That would be third gen. This is for new 2019 and up.
