Noise coming from the hood latch
fuelman99
My 05 ram has a really high pitched sqeak coming from the front of the truck. As far as I can tell its the hood latch, has anyone else had this problem? And if so how do you fix it?
shadow11
Banned
Houston TX
I think my truck is squeaking from their too. Im just going to grease it good when I get home and see if that does anything.
fuelman99
fuelman99
Good deal. Let me know if it works for you
lilfroger
5.9 CTD
Make sure everything in the latch assembly is tightened to specs:
-hood latch to the upper radiator crossmember bolts: 11 N·m (8 ft. lbs.)
-hood release handle to the instrument panel bracket: 9 N·m (80 in. lbs.)
-secondary hood latch and striker assembly to the hood: 11 N·m (8 ft. lbs.)
wrenchin4alivin
Latch Squeak
Make sure the rubber bump stops are adjusted right. There is one on each side of the latch assly(they have a hex head on them) Turn them up until the hood doesn't move at all when shut.
phorrestphire
