Noise when starting
Dustin1330
Every once in a while, when starting my truck, 2016/1500, it has a grinding noise. It’s almost like when you try to start a car that’s already started. Any idea of what it could be?
Here is the clip of what it sounds like...
Elevated 2013
Huntley, IL
I don’t hear anything wrong but someone else might chime in and say differently. You may need a shim by your starter based on your quick description but, like I said, everything I heard sounded normal.
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
Sounds like the bendix on the starter may be lagging a bit. Maybe an early indicator that relay is starting to wear out. Or the teeth on the bendix or flywheel may have some damage
RamCares
n/a
n/a
Hi Dustin1330,
If you believe your vehicle is not operating as designed and decide to have your dealer look into this further for you, please feel free to send our team a private message. We can connect you with a Case Specialist to work with you and your dealer.
Alex
Ram Cares
jws123
nj
Other then possibly the starter bendix staying out to long for a quick sec sounds fine to me.
