Not in park message
Danielposocco1
Redkey indiana
My 2019 1500 5.7 has a problem saying on screen "not in park " shifter is in park but truck only shuts off to acc mode unless I unplug battery then it will do it again after starting. I also noticed it takes hitting the button twice to start. I've had the battery undone for a month and it still does it. It was also parked for a month and now this started. I have 61000 miles so whatever is wrong I'll be paying for. Also no lights on dash. I'm thinking bcm failure. Thoughts?
jws123
nj
You need to have someone with a good scanner scan the truck not cheap autozone one and see if there are any stored trans codes. also how old is your battery? have you tested it newer vehicles can act funnt when batterys are weak.
