Not right - front tires worn on outside edges
cdn cj
Canada
To me your tread wear looks like you may have a teenage son.
At least that’s what my dads tires looked like back in the day….
But even I may have had an issue with spirited driving in a dually
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
This is an excessive toe (factory spec) issue. Nothing a rotation will fix.
Tell your alignment shop you want it set to 0 for the toe. ZERO TOE.
All you four wheeler guys telling him tire rotation, that is not the answer. Breaking down 6 tires to do a conventional tire rotation is a waste of time & money on a dually and is completely unnecessary as long as the alignment is set right. Doing a rotation in this case is a band-aid and still promotes unnecessary tire wear. Fix the problem and get the alignment with toe set straight to 0.
runamuck
Air Force
dfw
6.7 dsl
that's the same wear I have on mine after 28,000. the R/F one worn a lot on the outer 2". when I had it in for a recall last month the service notes suggested front end alignment needed. this must be a factory setup issue as lots of owners are getting the same kind of wear on the R/F tire.
ppine
Forester
Nevada
6.7 liter diesel
Normally if both outside edges are worn it is under inflation. One outside edge means out of alignment.
I rarely rotate tires but generally get 50-65,000 miles out of quality tires like Toyo or Cooper.
Now that I am older I drive like it. Many people just corner too fast.
Arturo Rojas
