Motorboater
Plan on doing some work on my truck (oil pan/reverse lights ) which is an 02 4.7 4*4 with manual tranny.b ought it a year ago and finally am at a spot to spend the money to bring her up above par. It's a bit rusty and needs some fixing up but it's fun to drive and I want to bring up to better than new interior wise exterior wise and performance wise.ive done a lot of reading and have some ideas but questions as well. I was thinking about the clutch fan but I read that I would have to run my a/c in order to make it work in which case I feel like the two cancel each other out? I also plan to off-road and hill climb this summer and the consensus seems to be that it will over heat without the clutch fan.
Maybe moving the iat and I saw something about more voltage to the tps that I'd like to know more about. Can I do anything else with the intake or would I need a tune to get a difference.
Long term (by 2019) plan on doing
08 intake manifold
4 56 gears(not sure if I'll get the same/better/worse results with my manual tranny)
SCT tune
72 mm throttle body
True dual exhaust ( I think 2 1/4 is what folks have had the best results with?)
Possible custom making a ram air intake
Cams( I read there's availability issues though)
A few other ideas that I'll reveal after I post up my 0-60
.....unless theyre high af
Any more ideas/suggestions for either this weekend tinker time or the long term ? Post em up
08 intake manifold
SCT tune
72 mm throttle body
