O2 bank 1 sensor 1
Whatfunram
Vancouver WA
Hemi6.1
Can anyone tell me which is bank 1 sensor 1? I think I know just need to be sure because I'm old and forget where I am sometimes so could be wrong
jws123
nj
Actually replacing the same sensor tomorrow should be drivers side upper sensor before cat.
W
Whatfunram
Vancouver WA
Hemi6.1
That's what I thought. Thank you for your time it is much appreciated
EdGs
FL
^^^^^^^This^^^^^^^
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
One way to remember for any V configuration engine, the side with the most forward cylinder is Bank 1. That most forward cylinder is also number 1 cyl.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
You never told us the code.?
Check the harness and chassis harness plug. Sometimes the pins get pushed out or the wire breaks inside the wire insulation. You may have to Ohm out the circuit to the PCM to make sure there is not a break. If it is an O2 sensor Heater malfunction code it could also not be recieving power.
But can't really say since you didn't post the code(s).
