OBD MX+
Johnny_B-Good
Pennsylvania
Ok so I put this purchase off forever and a day (Believe me, I drag my feet before buying ANYTHING). First things first, AlfaOBD gets installed later today. Are there any other apps worthy of having? Pin Puller is one I was curious about (cause that pin is required now and then). Don't want to make my device a battleground for apps. Just want to install and use apps that are required, and will be made use of. Thanks in advance to the most helpful, smartest bunch of folks I hang out with... :)
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
AlfaOBD has PIN puller now (though I have not used it) so I wouldn't buy another app until you try that first.
Torque Pro is a good app for monitoring PIDs if you wish to do that.
That's about it.
The pin puller on ALFAOBD works I can confirm, we used to to program a fob for @the_goodguy07 a few months ago and it's easy to use ...
^^^ this
It's a lot easier to monitor engine parameters with torque than AlfaOBD, you create your own "dashboards" of gauges. Easy to set up and the app is $5
joshhhh
