rick16706
- Sep 18, 2019
- 76
- 107
- Location
- Tucson, AZ
- 2019 1500 Classic - Warlock
- 6 Cyl 3.6L
I tried this post a short while ago and managed to screw it up, so I'm now going to try it again.
When I bought my truck in 2019, it didn't come with remote start, or so I thought. I remember the dealer telling me that I could have the factory installee alarm system for about $850.00 and when I told them I didn't want it for that price, they said they "would not activate it". I don't remember them saying anything at all about a remote start.
After joining this forum, I saw all sorts of articles about installing remote start on the truck, all of them rather expensive. Most were some sort of kit that needed to be installed and programed in some fashion. In addition to the parts and programing for the remote start itself, just about all of them required two new key fobs to be programed by the dealer, a locksmith, or AlfaOBD. Going through a dealer for the two new fobs could run several hundred dollars all by itself. At the time, I went with Start X, which I could install myself and could use my existing key fobs.
About three weeks ago, the Start X stopped working. After spending quite a bit of time trying to figure out what was wrong and how to get it working again, with absolutely no luck, I decided to hell with it and pulled the system out of the truck. In the process though, I figured out what I should have done in the first place. I ended up with a factory remote start for less than $10.00.
It turned out that remote start is already in the truck, just like the alarm system is. It just needs to be activated. I found a couple of videos on YouTube that showed how to install a factory remote start using AlfaOBD and was able to still use my original key fob. And the actual process of changing the settings and making one small modification concerning the hood latch took probably less than 15 minutes.
Both of the videos I found gave a coupe of different options for setting things up. One method required removing and then installing a new locking hood latch, which can be bought for about between $30.00 and $200.00. Another method used my exixting hood latch and using a resistor costing just a few cents. I went the resistor route. Also, most articles I saw talking about using AlfaOBD for setting things up, talked about getting two new key fobs, which again added to the cost and would require programing, but the method I used allowed for me to keep using the key fobs I already had.
The original key fob has a working contact for the remote start. It just doesn't have a working button. What I did was open the key fob, remove the rubber insert with the buttons, and replace it with a new insert. You can buy replacement key fobs or just the rubber inserts with the icons on them including the remote start button on Amazon or Ebay pretty cheap.
One additional point: Once it is up and running, the horn will honk twice and the parking lights will flash when you start the truck remotely. You can use AlfaOBD to turn them off if you want.
I thought this was worth passing on and it might save somebody some time and money. It doesn't make a lot of sense to me to blow several hundred dollars to get something that you can get almost for free. If you already have the AlfaOBD, you're all set. If not, this mod alone will pay for the AlfaOBD set up.
Here are links for the videos I used:
www.youtube.com
www.youtube.com
Activating Remote Start (2013-2018 RAM)
Our tech Joseph walks you through on how to activate the Remote Start feature on your vehicle using the AlfaOBD app. In this video we use a Dodge Ram Classi...
How to Enable Remote Start RAM | Dodge | Jeep | AlfaOBD
How to Enable Remote Start RAM Dodge Jeep using AlfaOBD we show how we turned on and programmed remote start on a key fob this should work for a ram 1500 250...
