Hey all!
I'm new to the forum, and am hoping you can help.
I have a '12 Express with the dual headlights (same bulb for hi/low), and put a set of HIDs in both the headlights and the fogs. Its the exact same kit I put in my wife's Jeep, which has had no problems for 3 years now.
At first, the headlight bulbs would switch from low to high with no problem. then the passenger side light would flicker real bad in high, and then finally stopped lighting in high at all. About a week later, the driver side started doing the same. Now, I have zero high beams. The lows work great, and no problems from the fogs.
My question is, does this sound like the bulbs, the ballasts, or the harness? Many thanks for any input you can provide!
