Odd size spare..... ok to use?
Art_in_CO
Colorado Rockies
2024 Limited
Picked up a 2019 1500 Laramie last week. The mounted tires are the correct original size - 275/65-18. But the spare is a size that's not even available anymore - 245/70-18.
An online tire calculator shows the 275/65-18 at 629 revs/mile and the 245/70-18 at 641 revs/mile. That's a difference of 1.87%.
Would it be ok to use that odd size spare if necessary or should I replace the spare with a correct size?
Thanks.
audiophile
5.7L
You probably wouldn’t notice a difference on the front since it’s so close in size but in the back I wouldn’t run it over 55 maybe if you have the limited slip rearend. If you have the open rear I wouldn’t worry about it.
I concur. Best would be find a matching spare.
I am not sure about that
i have 20" on my Ram
The temporary spare is not the same
17" STEEL SPARE WHEEL
FULL SIZE TEMPORARY USE SPARE TIRE
P275/60R20 BSW ALL SEASON TIRES
GOODYEAR BRAND TIRES
20X8.0 ALUMINUM CHROME CLAD WHEELS
That is from my Build Sheet, also know as the Equipment Listing
found here
