Odometer Correction (Installed new cluster)
duggyphresh
Odometer Correction (Installed new cluster) **SOLVED**
So I recently installed a new cluster to fix my inaccurate tachometer and temperature gage. Everything is working as it should. It is a 2001 Ram 1500 with the digital odometer. I've been told that the mileage is stored on a chip on the circuit board. Does anybody know which chip it is? Pictures would be appreciated (I will upload a pic of my old circuit board this evening). I can solder a circuit board and want to swap the chips so my mileage matches. My new cluster reads 53k and my existing cluster was 118k... you can see how this might be a problem. Thanks.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
Interesting to find out how this works, I would just let it ride with the 50k and keep it a secret.:naughty:
duggyphresh
duggyphresh
Its the one circled in red.
93C46 EEPROM 8 pin chip. Unsolder and solder onto new board.
DodgeTx
SEGUIN
So when you did that and had it all put back together did the mileage go back to what it was?
duggyphresh
duggyphresh
Sorry for the late response... Yes. Everything is working as it should now. Correct mileage and tach and everything. Its no easy task as you have to remove the circuit board from the cluster, which is a pain.
duggyphresh
duggyphresh
Just had the dealer adjust my pinion factor and now the speedometer is accurate with the oversize tires.
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
Really? A dodge dealership around here told me they couldn't change the speedometer for my bigger tires.
duggyphresh
duggyphresh
I gave them that guide and magically it worked. The first time I went in they said they couldn't do it (but they had their best tech say it couldn't be done haha) You have to calculate the revs per mile... It's all in that guide.
1SilverBullet2
North Dakota
01' like yours, I have 35's so mines off lol thanks for the link! It'll come in handy
