19 Laramie sportYes they can be depending on which model / version you are referring to.
No the truck I’m getting has level 2 pkgYes, do you have the 12” screen ? From what my dealer tells me with that they can flash so that you can operate it via the screen.
Link pleasecheck out the amp research power steps.. I had them installed on mine. They are controlled thru the OBD II port so no wiring splices. When you open the door they activate, close it they fold back up. Can't see them when they are not deployed. I love them.
Those will not work on the new 19. They are completely different, AMP said they will have them available by November.//www.carid.com/2018-dodge-ram-running-boards/amp-research-powerstep-xtreme-running-boards-1064981912.html?parentsubmodel[]=SUBMODEL|Quad+Cab
gived them a shout to see if the same model applies to 2018 1500
Not sure if that is true or not. My dealer flashed my computer after getting mine installed, and I don't have any controls on my screen.Yes, do you have the 12” screen ? From what my dealer tells me with that they can flash so that you can operate it via the screen.
Honestly, I’m hoping your guy was right and mine wrong. But that’s why I’m saying I’m not sure if it is true.^^^. It’s only sadly what I was told.
