Off-road 2
Tommie
East Texas
My 2020 Limited doesn’t seem to have an off-road 2 setting on the air suspension. What am I missing here?
Only have a off-road level.
magic280z
2019 1500 Laramie
I'm pretty sure off-road 2 is for Rebel with air suspension. All other air suspension just get off-road. Which is better than those of us with no buttons.
2019 Ram 1500 Laramie 4x4 - Crew Cab/5.7 Bed - 5.7 Hemi - 3.92 - Anti Spin - Level 1 Options - RamBox - BUG
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
I can't watch the video from work, so I'm not sure what it says. I'm sure it's correct since it's from Mopar, but
The video doesn't mention this, but if your truck has the ORG it's already sitting 1 inch higher, so like the Rebel, it only has 1 off-road height setting. That's how our 2020 Limited w/ORG is, only 4 height settings...off-road, normal, aero, and entry/exit. No off-road 2 setting.
Kevin Legge
Scottsdale
Hemi 5.7 eco
It says that the limited not rebel has 5 settings. Entry, aero, normal, off road 1, off road 2. However that is on the 21 limited
mikeru
Super Moderator
Eastern WA
2020 Limited
Not sure why we're talking about 2021 models. The OP has a 2020. You are correct that the Limited normally has 5 height settings. That is true for all models except for the Rebel. I can't speak for 2021's because I haven't seen one, but in earlier models, the ORG gives you a 1 inch lift above the non ORG models. So it's basically sitting at the "off-road 1" height when it's at the "normal" setting. I'm assuming the OP has the ORG if his Limited only has 4 settings for his air suspension.
Plankton
Mid West
Rebels have 4 inches of lift and 4 settings. Highest to lowest being:
  • Off-Road
  • Normal
  • Aero
  • Entry/Exit
Each one being 1" from the next. With the newer 5 settings you still get 4 inches of total movement, but they split the difference at the NRH to Aero to Entry/Exit modes at 1/2" intervals.
1" - Off-Road 2
1" - Off-Road 1
1" - NRH
1/2" - Aero
1/2" - Entry/Exit
AvatarofVictory
Central Texas
Ecodiesel 3.0L
It should have an offroad 2 setting, my limited does.
1 — Off-Road 2 Indicator (Customer selectable)
2 — Off-Road 1 Indicator (Customer selectable)
3 — Normal Ride Height Indicator (Customer
selectable)
4 — Aero Mode Indicator (Customer Selectable)
5 — Entry/Exit Mode Indicator (Customer
selectable)
The owners manual says"
Off-Road 2 may not be available
due to vehicle payload, an instrument
cluster message will be displayed when this
occurs." Its also not available over 25 mphh.
Tommie
Tommie
East Texas
Yes, I do have the ORG.
Rdizzy36
I have a 2019 limited. I’ve had it for 3 years and had off road 2. This week I notice it was gone. I don’t have a payload. Would anyone know why?
