Off Road Package Springs
Wiendog
Malibu,Ca
2019 1500 Laramie Quad Cab 4x4 6'4" bed
Does any one know part numbers for off road package springs for a 2019 Ram Quad Cab 4x4 Laramie.Or a source to find.Mopar is pretty useless they will only give springs for vin and can not say if they ORP or not. thanks
olyelr
Kewadin MI
go to the lot and look at a truck with the orp. The springs often have a part number on them. If not, grab the vin and then have then determine what springs are under it.
i just looked at one yesterday. It was parked next to the same truck without the orp... it certainly gives it an inch or so of height increase.
dhay13
Mine has the ORP. Been told it sits about 1 or 2" higher than the regular ones but haven't been next to one to check. I did measure mine to pull it in my 7' garage and it was about 79" tall with the cab lights and GPS antenna. My garage door was 82" and I had 2-3" to spare.
W
Wiendog
Malibu,Ca
What model is yours.
dhay13
2018 2500 SLT Outdoorsman 4x4 CCSB. Loaded with almost every option except leather, heated seats and sunroof.
olyelr
Kewadin MI
Is the original poster talking about a 1500 or 2500? I guess it really dosnt matter with the question at hand, but regardless it is info that would be beneficial.
I think the op has a 1500 (5.7 motor in his avatar), which is way shorter than a 2500.
W
Wiendog
Malibu,Ca
Sorry It is a 2019 Ram 1500 Quad Cab Laramie 4X4.
dhay13
Sorry I missed that. I didn't realize they made a 1500 with ORP
keisur
Cypress, TX
Mines a 2020 1500 crew big horn (lone star) with the ORP. Pretty sure they would be the same springs. It's new enough to have the P/N tags still on the springs so I will check when I get a second and post pics if the tags are still on them. I have pics of the fronts but didn't take pics of the rears yet.
EDIT - Sorry, Part Number tags are no longer on the rears on my truck. they're still on the fronts though. So long/short...no pics.
MoPowered
Retired
Orange County New York
Call your local dealer and talk with the parts guys, they should be able to run up the vin and cross reference for the no#. The springs are are vehicle specific based on your truck model and option’s.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
I believe the springs are the same the strut is different the spring perch is set higher. Not 100% sure so double check me. But pretty sure that’s how they did the orp
ram1500rsm
Trabuco Canyon, CA
You can get Eibach E30-27-011-02-02. These are Eibach 1" lift springs for the back of the DT truck. (Non ORP version models). they mesure the same as the ORP rear springs, 20.5", should give you the same lift as the ORP's
NewBlue
Old thread I know but my 2019 Laramie quad cab 6-4 box with ORP has springs PN 68262686AB.
Any one know what the PN is for the same truck without ORP?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Non ORP Crew Cab with 6.4 bed
Below is ORP or Rebel
hunterdan
SE PA
2019 classic
Digging up some bones here, but are the 5th gen springs progressive or no?
