I've have a side project I'm doing and I'm looking for some schooling in the audio department.
My question is for the audiophile's in the group.
What is the correct why to match an amp with speakers? I dont want to buy just any old amp and throw a set of speakers at it only to blow everything in a few days lol. Any help would be appreciated
After you have selected your speakers look at how many continuous watts they're rated for (that's going to be labeled RMS).
The speakers will also have a rated impedance like 2 or 3 or 4 ohms (most often in mobile audio)
If you're shopping amplifiers, find one whose RMS Watts per channel - at that impedance (ohms) - is similar to, or higher than the speakers you've selected. And of course has the appropriate number of channels... you don't need a 5 channel amp for two speakers and also a single channel amp or a subwoofer amp won't be suitable for a pair of stereo speakers.
Punch those numbers in here and you'll get a voltage
https://ohmslawcalculator.com/ohms-law-calculator
Example if your speakers are rated 60 Watts each (that's per speaker not per pair) and they're 4 ohms, you're going to get 15.5 volts.
Now after you've wired everything up
except the speaker wires, make sure any kind of bass boost, EQ, any of that other B.S. is turned off and then follow the steps in this video:
If your amplifier is rated for fewer watts than the speakers, no problem. Just find the amplifier specs for RMS Watts per channel at the impedance (ohms) that your speakers are, and use that number when you're calculating instead of the speaker RMS Watts.
