Oil Drain Valve Survey
Status
Not open for further replies.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
Anyone using an engine oil drain valve instead trying to remember what wrench size the Hemi drain plugs are (13 mm dia, FFS), along with your 20 other engines? Most other automotive oil drain plugs are 15 mm dia wrench, the Japanese engines are 17 mm dia wrench.
Reliability (don't leak over the years)? Brand? (Fumoto, other)?
Thanks
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, 3.21 rear, 8-speed
I had a Fumoto on my '06 Tacoma for a little while, the whole time I kept re-thinking the decision to use it at all. Ended up selling the truck at 73,000 miles for reasons unrelated.
So having done many oil drains both with and mostly without, it seems to me those drains are a "solution on search of a problem". Mostly that anyone who needed one probably shouldn't be with 50 feet of any vehicle with a wrench in their hands.
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
+1 no valve for me either.
I forget too, but I just grab a rack of metric sockets and a ratchet and toss it under the truck before I start doing an oil change.
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
If you throw the the kitchen sink in that mix,then you got it all covered G :Big Laugh: :Big Laugh: :Big Laugh:
It's only a handful of sockets. It's not a big deal.
Getting back up to grab a socket I didn't have ****** me off LOL. So I have a few sets that I move around a lot.
Dean2
Near Edmonton
No drain valves for this boy! No Chancey Mr Whalen!
As far as the right socket, I cheat and use a lift in my garage cause I am too old for crawling on the ground any more. Makes everything a whole lot easier, including walking over to the tool box for another socket.
You and me both, ;)
The older i get,the harder it is to get up off the ground to grab that 1 wrench or socket you forgot to grab the first time around:(
I gotta move closer to Dean and buttar him up:Big Laugh:
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
I had a Fumoto valve on one of my previous trucks. Never had any issues with it other than the fact that there’s slightly more oil that doesn’t drain out. So I don’t have them in any of our vehicles anymore.
Each of the five vehicles we own has a different size drain bolt except for the two that have Hemi’s. I took a sharpie and wrote the size of drain plug on the rad cover of each so I can see it when I open the hood. No need to remember the sizes.
caulk04
Supporting Vendor
I have one, only because I already owned it. Previous Jeep had a skid plate over the oil pan and the valve was nice to just toss a piece of hose on instead of pulling the plate. So I put it on in the truck, no tools needed for my oil change.
Docwagon1776
Midwest
None of the above.
I have a little notebook in each vehicle. On the inside of the front cover I have written the part numbers for the spark plugs, air filter, oil filter, what type of oil it uses and how much, and the oil pan drain plug size (and filter housing wrench size if applicable).
Then I use the notebook to keep a running history of maintenance. Date, miles, what I serviced, etc.
HEMIMANN
HEMIMANN
Minneapolis, MN
That dream sailed when being let go by corporate.
HEMIMANN
HEMIMANN
Minneapolis, MN
Why would you want to add an extra failure point to your oil pan. And it also takes the ability away to check your magnet on your oil pan Bolt.
Because my body is failing. How's that?
Dropped bolts in oil, oil all over (even with gloves), etc.
DILLIGAF
Canadian Forces
Canada
Join the club :anitoof: , Why do you think Veterans Affairs pays my 9g a weed a day. :hat: and I pop Oxys like its candy
You're going to need a better excuse then that with me. I cant feel my arms after 2 hours of work due to my nerve damage and the multiple elbow and wrist surgeries.. Hence the 2 post lift .
Heck I bend over wrong and I cant walk for a day and im only 46.
I said id never run one. I never said you couldn't.
Status
southalum
