Oil Drain Valve Survey
Status
Not open for further replies.
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
I think it really depends on how much driving you are doing and what your OCI is.
For me, it's not often. Once a year and a few k miles so no point worrying about making the process easier.
If you are changing it a few times per year and like the convenience, go for it! I know a ton of members here run them and I have not heard of any issues using them.
oe542bob
Hemi eTorque 5.7
Anyone using an engine oil drain valve instead trying to remember what wrench size the Hemi drain plugs are (13 mm dia, FFS), along with your 20 other engines? Most other automotive oil drain plugs are 15 mm dia wrench, the Japanese engines are 17 mm dia wrench.
Reliability (don't leak over the years)? Brand? (Fumoto, other)?
Thanks
I’ve been using the Fumoto valve on 4-1500 Rams, 1-2500 Ram Cummins plus my HellCat. Never any leaking or failures. Never had one accidentally open.
Now, I will say, and this was MY MISTAKE, I installed a cap over the nipple after draining the oil, BUT failed to close the valve. Put oil in the truck and on the second time I drove it, the low oil pressure light came on as I was parking in a lot. My first thought was, oh it must be a bad sensor. Right after I parked I decided to look under the truck before I went inside the building. Yup, oil was draining onto the parking lot. Crawled under, closed the valve, and had a friend bring me some oil. Got lucky there.
For me I just like having the convenience. To each their own.
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
haha got lucky for sure! I would probably do the same thing at least once if I had the valve.
HEMIMANN
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
Yeah, just curious what folks were doing, not as big a deal as my recent changes in oil selections after many years of running Red Line in the Hemi and PUP in the other vehicles.
GDI and API SP has really thrown oil requirements to the wolves. I get that change is the only constant, but does it always have to be for the worse?
I appreciate most of the responses, measured against not assuming everyone's capabilities are equivalent. In my case limitations are physical. Mostly. lol
Randy Grant
Army
KITTITAS, WA 98934
Thanks
yes and a filter relocate.
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
Thanks
I wanted to post: That’s what Vise-Grips are for! :lol:
But, I use an extractor on some and Fumoto on others.
Docwagon1776
Midwest
If you don't want to under the truck at all, you could get one of those oil extractor pumps that you feed a tube down the dipstick tube and do a filter relocation kit if you can figure out a good place to mount it you can reach from under the hood.
Yeah, you'll leave a little more oil behind but who cares?
mtofell
Had one on a previous truck and it never gave me any trouble. Never got one on this truck.... just not enough of benefit to justify. As for failure points, it seems like a wash. Standard plug can leak, get x-threaded, etc. Valve can have its problems too.
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
I've got the Fumotos on both my trucks. The main reason I went to the drain valves was to significantly reduce the initial mess when the drain plug first comes out of the pan: success, no more oily hands and no more splash spills on the garage floor.
HEMIMANN
HEMIMANN
Minneapolis, MN
THIS
HEMIMANN
HEMIMANN
Minneapolis, MN
I'm not that far gone. Yet. lol
In fact, my 3/4 ton is tall enough where I have to use a ladder just to fill the damn thing, so using an extractor is more of a PITA than sliding under the truck, as the same aspect makes sliding under easier without having to jack it up.
It's more for making the draining easier and less messy is what I'm after. Those extractors are necessary for unreachable oil drain plugs like on I/O boat engines, etc.
My oil filter is easy to reach on the 3/4 ton 6.4 Hemi - they put a 90 degree filter adapter on the engine block so the oil filter sticks out to the front of the engine.
I guess I should have explained I have a Ram 2500 with the 6.4 Hemi in my OP.
oe542bob
Hemi eTorque 5.7
Just a short follow up, it was the 1st time I installed a cap on the nipple on the Fumoto valve. Even as I put it on, I thought this is kind of a waste of time. But I installed it because I had a cap and it fit nice and tight.
Since that time, I’ve NEVER used a cap again.
1979 300
Southeast PA
6.4L
I stick a piece of painter's tape under the hood with the mileage, date and socket size whenever I change oil on my vehicles. It makes it easier the next time.
bm02tj
B C Canada
Yellow paint pen 13MM 6.6 ltr 7gt so I can drain and refill with correct amount
Status
Arturo Rojas
