Oil in the air filter
meltino
Oregon
Does any one have any tips on how to troubleshoot this problem?
I noticed this after replacing the PCV valve with a new mopar (for regular maintenance). This picture is after about 300 miles on a new air filter.
Could the new PCV valve be causing this?
tidefan1967
Summerville, South Carolina
If I had to guess I would say you have a bunch of carbon goo built-up in your intake manifold and its worked its way to the airbox over time. I would take everything off and clean it, even take some throttlebody cleaner and clean inside the upper intake with some rags and of course don't forget to clean the throttle body while you're at it. I assume you have a bunch of miles on it and yes the PCV could be having some small effect on it too; make sure it rattles when you shake it.
CorDog009
East Texas
Mine has a small stain in the same place under where the pcv hose connects to the airbox. I'd throw a catch can on it just to be on the safe side. I'm going to build another one of my homemade catch cans for mine. Grab a cheap air compressor air/oil separator and throw some barbed hose ends on it and put it inline in that hose. I did that on all my LS cars, usually for about $15 total.
WhiteExpress
Midland, TX
That's pretty gross. I would start at the air box and work your way back to the PCV valve cleaning all the pipes/hoses/whatever is in there.
It seems like maybe you weren't getting and positive venting, and now you are.
meltino
meltino
Oregon
I believe you're right, the old PCV valve wasn't rattling. I took all the hoses out and ran compressed air through them, a lot of that stuff came out, hopefully it doesn't come back. Thanks guys.
Arturo Rojas
