Oil life indication?
nickpohlaandp
Lake Charles, LA
So here's a question. How does your oil life indication work? I mean, is there some sensor that analyzes the properties of your oil, monitoring the acidity and contaminant levels, or is it just a BS number that computes from a set value whenever you reset it?
Kotta390
I too am intrigued. I change my full synthetic oil at 5000 miles and my OCI says I usually have 49-51% left every time.
nickpohlaandp
nickpohlaandp
Lake Charles, LA
I've read that there's two ways manufacturers do it. One way is using an algorithm in the PCM that calculates the oil life based on many factors (idle time, drive time, temperature, load, etc.). It's a constantly changing formula built into the PCM that comes up with an average and displays it on your EVIC. The other way manufacturers do it is with actual gauges that actually measure resistance, viscosity, water content, etc. I'm curious to know which is used on our trucks.
I don't want to say this, but I'm betting ours is the algorithm method.
Reactions: SyN
Bobbo
Los Angeles, CA
I believe it calculates it based on driving styles. Takes into account things like engine RPM, load, temperature, etc... So if you do more city driving, it will have you change the oil sooner than mostly highway driving.
Sent from my LG-H820 using Tapatalk
Kotta390
I can almost guarantee it. The algorithm theory is something I have been wondering if Chrysler used. Your second theory on the calculation is probably for more advanced vehicles out there like your Jag, Mercs, and BMWs or higher.
nickpohlaandp
nickpohlaandp
Lake Charles, LA
Without knowing for sure, I'd bet $ that you're right. An algorithm like that would actually be pretty easy to write, and in mass production, easy equals less money, which equals more profit.
develand
I don't pay attention to it. I use it more for the miles since last change.
Ram Man
FL
2013 Sport
I am at 4,950 miles on synthetic and I have 49% left... With that being said I will not be going 10,000 before I change the oil.
nickpohlaandp
nickpohlaandp
Lake Charles, LA
Oh, I agree. I change mine every 5K, but I was just curious if anyone knew for sure what method is used for the display.
Danno
Mid Atlantic
2016 Power Wagon
From the owners manual
Oil Life Reset
Your vehicle is equipped with an engine oil change
indicator system. The “Oil Change Required” message
will flash in the DID display for approximately 10
seconds after a single chime has sounded, to indicate the
next scheduled oil change interval. The engine oil change
indicator system is duty cycle based, which means the
engine oil change interval may fluctuate, dependent
upon your personal driving style.
sandawilliams
Pueblo West, Co.
6.4 hemi
Oil Life Reset
I have been to two different dealers since buying my 2014 new. They have both told me the same story- change the oil when the indicator says to. I researched online and found many more articles that agree. I wonder how reliable this is but it is costing the dealers money (less from oil changes) to tell people that. Neither of the dealers put the old style date and mileage stickers on the windshield anymore.
MANual_puller
Shade tree grease monkey
Vinton, Iowa
2011 Moose
5.7L hemi
I just ignore mine, I reset it when it annoys me. It seems to think I should go 7500ish miles on the oil. I use Mobil 1 but I still don't feel the need to go that far on oil.
jag1886
Boise Id Gods country
Demi 5.7 S&B CAI, flowmaster merge collector, Gibson cat back, oil catch can, 87
It's basically a timer, like the light on your refrigerator that tells you to change the filter. If you don't reset it at an oil change it doesn't know you changed the oil.
socalledchad
Mine has always seemed to be on par with 10k miles..if I drove 5k it says 50% left....even thought I pull 4 k 10% to 80% of the time and all types of driving styles...and winter summer changes...makes me believe it's just millage ...but it's said that there is more to it
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
I have heard both algorithm and mileage base opinions. I will say that with mine, you can count on a 1% tick loss every 80 miles not matter how I drive which is in line with my recommended 8K change interval on the 6.4.
thediamondsaint
Are you sure it's not just based on the miles? That seems to be the only number indicated in the dash menu for Oil Life. I'm on 49 miles since my last oil change.
Danno
Mid Atlantic
2016 Power Wagon
Once again....
"The engine oil change
upon your personal driving style."
Ram Man
FL
2013 Sport
Exactly. If it was an algorithm with sensors and such and actively monitored the oil, then there would never be a need to reset it when it got low. Because if it looked at the oil, it would automatically go back up to 99% when you put fresh oil in. But we all know that is not the case...
Settled.
BlakDak71
Like everybody else has said, the PCM calculates it based off driving habits, ambient conditions, cold starts, idle time, etc.
No magic sensor to analyze oil properties. It's really just an idiot light and should be treated as such. 5000-6000 miles is safe with newer engines, provided you actively check your oil - especially with the Hemis tendency to suck oil through the PCV system.
nickpohlaandp
nickpohlaandp
Lake Charles, LA
In 5000 miles my catch can was maybe 1/4 full, and that's being generous.
