Oil On Engine Cover
theskier74
New Hampshire
Hey there everyone! First time poster here. I changed my oil about 2,500 miles ago and today I popped the hood and what looked and felt like oil on top of my engine cover.
Any idea of what could be going on here?
‘16 hemi with 30K on the clock. Oil pressure while driving seems to be solid.
theskier74
theskier74
New Hampshire
OP here. Could it be coming from the timing chain gasket and thus spitting oil all over?
Daw14
South Florida
Did you have a messy oil change ? Drip oil all over steering rake? Then drove at speed ,flinging oil upon the engine? Maybe?.
PoMansRam
East Aurora NY
Water pump flinging coolant around would be my guess given the area.
A coworker of mine just had the water pump replaced on his 2015. Not leaking yet but was squealing.
JB1
Houston, Texas
That's quite a bit, seems like you should be able to see that leak.
RamCares
n/a
n/a
Hi there @theskier74, we certainly can understand your concern here! If you are not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your Ram dealer, please be sure to follow up with us via private message. We would be more than willing to escalate your situation to a specialist who can work alongside you and your dealer while your truck is in service.
Kathryn
RamCares
Brian Mealer
Birmingham, AL
Following. I discovered the same thing this weekend on my 2015 Ram 1500.
Sent from my SM-N975U using Tapatalk
theskier74
theskier74
New Hampshire
Never figured this out but it never happened again. So who knows. I can't remember if I checked the coolant three years ago but definitely just ran out of coolant a few weeks ago. Probably should have kept a better eye on it. But oh well. Could have easily been oil all over the place from a sloppy oil change that I've done or coolant flinging around. Not sure.
joshhhh
