Oil Pressure
RBR73
Maryland
Hey guys. Another question. Is this a normal reading for oil pressure? (Pic attached) the gauge doesn't have numerical markings so I have no clue. I never really paid super attention to all these things with my truck when it was stock, but since I started making mods I'm nervous as hell about how my truck is running so I find myself paying attention to every little detail. I do notice the pressure seems to be lower in warmer weather. I'm sure the outside temp makes a difference.
Padilen
That's about where mine is.
CVX20
Ont,Ca.
2019 Classic Express
The gauges on most vehicles are more of an indicator than a gauge.What I meen is that they're really usually not all that accurate.The only way to be real sure is to hook a known good mechanical gauge right to the engine block where the sending unit/sensor is.
Ambient temp could slightly affect your readings though.Clearances are going to change in a hotter engine.
bassheadhemi
Montreal, Canada
You should also have a numerical value in the EVIC in one of the screen under vehicule info
