Oil ?
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Thanks Burla.....good to know
I see RP has slight advantage over Mobile1 with media filtration but everything else pretty much equal.
Don't think it has a $5.82 advantage though.
Amazon selling RP for $14.99
Walmart selling Mobile1 for $9.17
But thanks to your info I will now be using the M1-210A over the M1-113A
One thing to consider is those tests where when the media was brand new fresh, where 100% spun micro glass shines is the longer in use the better it gets. Fram Ultra that won the test as a whole is cheaper then m1 and doesn't have the paper element. I would suggest you try one of each and cut open your filter, see if the m1 stiffens up, if it does then you simply have higher micron contamination rolling around your engine.
ISellRams22
TxnRamTrvlr
My manual states 5-30w synthetic. I just changed it this last weekend to 0-40w Mobil 1. LOL
I have the same in my 2011 2dr. Rubicon and wife's 2015 GC.
In my opinion, the 5-20w flows too thin at operating temperature. I live in Texas so
a thicker at operating temperature is better.
Just my .02.
how do you like it now thats youve been using it a few months
crackerjack1957
Don't think the newer Mobile1 filters (A) have paper element, its synthetic.
Went from 15k miles to 20k on the new ones, which I would never attempt.
ok, my weakness is always not keeping up with most current info. Oil industry changes faster then I can comprehend. I will look into it.
This is what the current m1 filter page says...
Mobil 1 oil filters are key to getting the most from your motor oil. Our advanced performance filters for cars and motorcycles use synthetic blend media to help you get better engine performance and longer engine life.
They still use paper blend...
leroys73
Dallas Area
? type of oil for the new 2018 5.7
called two dealers. one said full synthetic, One said synthetic blend, and some manufacturer number
I called said 5W-20. and never said anything about synthetic.
she did say ApI, ms- 6395
but no one could tell me what the truck came with.
Check the owners manual.
crackerjack1957
So the key word is blend that makes it paper?
RammerHarder
PA
On the K&N filter, the rubber seal ring is not crimped in the canister like the Amsoil and RP filters.
Fitzy,
i dont think the crimp around the oil seal really has a purpose after its installed. The rubber ring stays seated in the groove after installation.
The K&N filters that leaked on my hemi`s were both leaking at the metal crimped area on the body of the oil filter, not the o-ring rubber seal.
Terrible K&N craftsmanship and construction is why they are leaking. Only reason the rubber seal would leak, is the installer didn't install it properly.
crackerjack1957
RammerHarder
PA
I seen that but they still do not say exactly what their filter media consist of only saying synthetic blend. So I assume its cellulose (paper) & synthetic fibers meshed together.
Yeah i think the same thing too. I dont think these oil filter companies will give up their recipe secrets though.
For you guys not wanting to buy Royal Purple Filters you can get Fram Ultra XG10060 which is for late 4 gen rams for less then 10 bucks on amazon.
If you buy the case of RP you can save a couple bucks, these are 13 dollars and change for unit...
Royal Purple 20-820-CS, (Pack of 6)
Ramnewbie
Fitzy,
The reason they leak from the gasket and possibly the reason that people are reporting that the filter loosens during service is because center hole is not tapped square to base plate.
RammerHarder
PA
I would have to agree, i`ve seen that too. My problem was the seam/crimp, both mine leaked at the crimped part of the filter body.
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
Anyone have a part number for the oil funnel that locks into the fill port on the Hemi like the oil cap does. I can find them for 3.6 and 6.4 but they do not say they fit the 5.7.
crackerjack1957
RP shipping my way........lol...........thanks
Orca
