On board compressor for airbags?
EdmontonRam
Sherwood Park, AB
2020 1500 Sport (DT)
Hi guys,
I am putting Air lift 1000 bags in my 2011 crew cab as well as an on board compressor. The compressor kit I bought is asking for a power source that is 15A switched ignition power. Does anyone have an idea where I can grab this from under the hood??
Thanks in advance
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Just look for one of the fuses under the hood that is 15A and run a jumper from it. I would choose something if possible that is not essential in case it blows for some reason. I think I would go with towing lights fuse or something like that. You will have to look under there.
$miley
E
EdmontonRam
Sherwood Park, AB
Thanks, I will have a look when I get the truck back from the dealer today. It's in for a backup camera replacement. I am planning on running a relay to power it and use a ign switched wire to turn the relay on. It seems like this TIPM is not to be messed with.
