One touch up/down problem
FlatbedHemi
My windows have gotten to where the one touch up and down feature works intermittently. I assume its a common problem since the last 2 trucks I have had, had the same issue. My question is, whats the fix for this? Is it a switch problem? A program issue? Windows still work, just don’t always go down/up with the one touch feature.
FlatbedHemi
FlatbedHemi
Yeah, I did that, but it isnt a permanent fix. Just wondering if its a fault in the switch, and if it would be worth it to replace the switch, or will it be one of those gremlins that pops up a short while after the new switch is installed.
KC Cryptkeeper
KCMO
2015 Ram1500
How is it not permanent? How often do you have to re cal them? It maybe in the controller module inside the door, the switch just starts movement then the controller sets the latch unlatch in the circuit.
FlatbedHemi
FlatbedHemi
Usually a couple times a month. Seems to happen when the truck is off camber like when entering the highway from the deer lease or going up the driveway from the mailbox.
KC Cryptkeeper
KCMO
2015 Ram1500
Have you ever disconnected the battery then did the calibration? Resetting the module maybe helpful.
RamCares
n/a
n/a
Hi FlatbedHemi,
If you decide to visit your dealer and would like additional assistance throughout the process, we are available through private message!
Laura
Ram Cares
magician
I took mine in this week and was told they would have to charge me $135 just to diagnose the problem. That’s crazy to charge that much just to look? Loosing confidence in this dealership fast. They charged me a $100 for a “4 wheel alignment”? How do align the rear wheels on a solid axle?? Never gave me as found or corrected angles on any of them either, how can you prove nothing was done at all other taking my money.
joshhhh
