Opt7 led fog light flicker
Citymoto
NYC
What's going on guys I recently purchased led fog light bulbs from opt7. Did some research people said they were good. However the bulbs do not work without some sortve wiring harness. I have morimoto led headlight bulbs for the lows and highs (quad projectors) only issue was I had to purchase a mopar spec harness from theretrofitsource.com
i would like to buy a bulbs that works instead of a bulb and a $100 harness does anybody know of any billed bulbs that will work on a 16 ram 1500 (9006). Thanks matt
EagleChief
Oklahoma
2014 Big Horn
Dang, that's hard to read...
Anyway... OPT7 can send you the stuff you need for the bulbs. Should have some connectors and resistors that came with the bulbs (if you gave them your truck info). Contact them through email or Facebook and they should send you the extras.
Citymoto
Citymoto
NYC
I sent them an email they just offered to send me a return label.... has anyone installed these bulbs with an additional harness or flicker module ?
andrew
South Florida
2019 Classic
i installed a pair of 9006 opt7 "FluxBeam" bulbs in my fogs tonight and didn't have any issues with flickering. i used all the wiring that came with them except for the harness extenders. i however ordered the headlight bulbs instead of the fog light bulbs because I've read people who bought the fog light bulbs weren't happy with the output. my truck is a 2013 with retrofitted quad headlights, so maybe I'm not getting the same problems you are since I'm using HIDs for low beams vs your leds...
Citymoto
Citymoto
NYC
Thanks for your reply I did order the fog lights and already returned them I might order the headlights and see how they work in the fogs. I believe 2016 and later have a different canbus system that doesn't like to work but hey it's worth a shot.
