Outside temp way off
kroppshop
Hope, BC, canada
I noticed today the outside temp showed on the screen is 15 degrees Celsius, but we have right now probably 24-26 degrees C. (No engine light)
Is there a way to reset the sensor?
1999 White C5 Coupe
Have you read your vehicle owner’s manual?
The ambient temperature display has different operating features - which can cause confusion with the display temperature.
Depending on vehicle usage prior to a new start, you may have to drive several miles to reset / display the correct ambient temperature.
If you meet all the parameters for the ambient display and it is still inaccurate, you may have replace the ambient air temperature sensor.
Tahoebronco
Dayton, NV
Last year I noticed my ambiant/outside air temps reading about 15 higher normal. I'll check the sensor to see if it is faulty.
Travelin Ram
There’s some bugs in this function in my experience. Sometimes it’s spot on. Other times it will freeze up and show the same temperature for very long periods, -an hour or more- as the actual temperature varies significantly (changing elevation etc.)
I’ve had two vehicles from FC do this.
K
kroppshop
Hope, BC, canada
I noticed that too. I installed in the meantime a Tesla Style Android device and I see now the temperature always correct from The Weather Network.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Doesn't that need a WiFi connection? Do you find it to be a pain turning on Hotspot on a phone or Hotspot generator? I have a little black box I use so that I can view movies or YouTube videos on the stock unit but for weather to update it must hook up to a wifi.
K
kroppshop
Hope, BC, canada
Yes, it need Wifi, but I turn on my hotspot on my phone before I enter the truck, takes 5 sec. And it is also used for traffic news on the navigation with Google maps. And it all does not need much data and it is well worth it for the big screen and great quality of the picture. And it has Android Auto anyways.
K
kroppshop
Hope, BC, canada
Park your vehicle so the outside driver's side mirror isn't in the sun. Problem solved :)
This does very clearly NOT solve the problem. If sun or not, the issue is still there and I am not the only one with this issue.
