Overhead Courtesy Lamp assembly
MYMISSIONISFISHIN
Rochester, NH
I was replacing one of the bulbs in my courtesy Lamps and somehow broke something on 1 side and the lense that is supposed to click up and down / off and on, is no longer clicking. I was wondering if I have to buy the entire assembly or are the square courtesy lamps replaceable? My truck is a 2014 Ram Express. Just the basic courtesy lamps, no electric rear window, garage door opener etc. Looks as if its a pretty easy job to remove the assembly and watched a couple videos on YouTube so should be able to remove it pretty easily.
Gwerner74
NC
It's possible that you may have just popped the switch out of place, I did the same thing the other day. Pull the overhead housing down and look for a plastic pushbutton switch. On my '15 it was white and just plugged into a 3 pin connector.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
If you just need a replacement lens, I think I have one. Take a picture of what you think is broken. I have quite a few spare overhead console parts.
