jswhiteknight
I've got a 1997 Ram 1500 4x4 with the 5.2 magnum motor with roughly 223,000 miles. Its been feeling down on power for some time but still ran ok. It overheated on a pretty hot day and I wasnt checking my temp gauge so I'm not sure how long the gauge was sitting at H before it stalled. It blew all the coolant out of the rad overflow bottle. After it had cooled (several hours) it fired back up with no noise and sounded normal besides having no coolant.
I did a compression check on the driver side with all cylinders being between 150-160 psi. Passenger side had the blown gasket on cyl 2 and 4. I removed the heads and took them to a machine shop and he told me they were cracked (not surprised. lol) and quoted me $450 per head for new ones.
Now here's my question. Would it be worth just sticking new heads on and putting it back together or should I suspect there to be other issues further in the block? I can still see crosshatch marks in all the bores and still had its usual oil pressure.
I'm torn between just sticking a junk yard motor in it for $450(with around 200,000 miles from what they told me and that doesn't sit well with me). Just as a temporary fix being its my daily driver and pull the rest of the original motor and go though it and replace the worn out stuff as time and money allow OR just hope for the best and reassemble it.
When I pulled the intake it had a very noticeable and bad burning oil smell (which would be expected) but did make me worry about the rest of the engine.
Sorry for the wall of text but I just wanted to give enough info.
