ozone generator
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
I finally broke down and bought my own ozone generator. This one in case anyone is interested.
Ozone Generator
When I bought my truck it had 10 little tree air fresheners hanging from the rear view mirror. No amount of cleaning was able to get rid of that smell. I can't stand artificial scents. I don't know what he was trying to cover up, but every time I got in the truck all I could smell was air freshener. Most people would have probably found it pleasant. I didn't.
While I was able to get it down to a manageable level, I could never really get rid of it. So, I finally broke down and bought an Ozone generator.
After reading the negative reviews, I realized what they had all done wrong so I figured I'd share.
1. After unboxing the generator, take it outside and plug it in and run it for 30 minutes. This is a new piece of electrical gear. It will experience flux burn off and you don't want that in your car. Make sure it's in an open area. I had mine out in front of my garage, pointing towards a semi enclosed work bench and even though it was outside when I went over to check the whole area was saturated.
2. After doing the initial burn off in step 1, it was obvious this thing was just too powerful to be ran for any longer than 15 minutes in an enclosed space like a car interior. That's the second biggest complaint is people say it takes 2 weeks to get rid of the ozone generator smell. So after cleaning your car and letting it dry, use this to finish off any lingering smells using short bursts. I used 15 minutes run time with 45 minute soak afterwards. Then open the doors and let it air out. I did this in the evening so I could check the smell in the morning on a fresh nose.
3. When running the generator, make sure the interior is sealed as best you can. I saw videos of some people leave the windows open a little to allow fresh air in. Don't do that. I ran the cord through the window, raised it up until it was almost pinching the cord and used painters tape to seal it off.
4. Be prepared to do several treatments. I came out this morning, no air freshener smell (I win!) but I do expect it to come back. When it does, I'll treat it again.
Especially if you are trying to get rid of something like cigarette smoke, remember what that is. The oily tar filled vapor that was exhaled by someone. That's like a paint mist. Expect to have to treat that several times.
Since I only ran the unit for 15 minutes I had no over powering smell. It was more an absence of air freshener that I smelled.
Anyway, I recommend this, if that means anything. It worked, and I didn't waste my money.
markabby
Monticello, Kentucky
2020 Limited
i use mine once in a while. i wish there was a way get it inside the air ducts and get it to flow thru the a/c coils without turning the truck on.
i might try attaching a 3" flex hose to the OG fan and attach that to one of the vents. maybe that will do the trick (?)
diymirage
Banned
do these things require any "fuel" or is it simply plug and play?
no fuel other than the electricity that it runs on. An ozone generator works by using an electrical charge to split oxygen from the air allowing it to recombine with other oxygen atoms to form O3
diymirage
Banned
thats pretty awesome , i was talking to a buddy about a house that had a musky smell to it and he suggested one
id never heard of em, so i was kinda curious
never considered the thought it could take care of smells in cars aswell
I used one to get rid of cigarette smell out of a Ford custom E-150. Took two 40 minute sessions about a week or so apart. Just be sure to leave the vehicle air out completely after running the ozone generator in the vehicle before driving down the road with the windows up.
Docwagon1776
Midwest
We use them, along with UV light, to eliminate odors and lingering biohazards in fleet vehicles. Turn the HVAC on recirculate to get in the vents. Air out the vehicle when you're done. It's not toxic, but it's also not oxygen your body can use so you can suffocate if you get the concentrations to high just like with helium.
RamDiver
Marlborough, Ontario Canada
2021 DS
Ozone Generator
Thanks for the tip, I can think of several uses for this unit.
I just ordered it from Amazon at 23% off the regular price. It received top reviews from several sites that I looked at.
markabby
2020 Limited
we also use it around the house in various rooms...especially after the holidays when people leave. not saying they're dirty people, lol, but just to refreshen the bedrooms.
and don't breathe the ozone air!!!! keeps pets away too!
