p018c error
Wynded12
wisconsin
Ok, guys, I had the p018c error pop up. I had the fuel pressure sensor, driver moduel, fuel pump all replaced. I still have issues with it stalling after start up in the morning. It dies out until its warmed up. Now it stalls out when I slow down at an intersection. Could it be my PCM??? I have a 2019 Ram big horn classic with 40k miles. Also, is it true that hemi's dont like the cold? I was told that hemi's wont idle right when its cold till it warms up. Already blew almost 2k on this truck and still not fixed
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
I'm not familiar with the p018c error, or what it indicates. There are some 4th gen owners here, but since this is the 5th gen forum I'm not sure you'll get as much help as you would if you posted this question in the 4th gen forum. Even though your truck is a 2019, it's technically a 4th gen Ram 1500.
What you heard about Hemi engines not liking the cold is not true. Maybe older carb'd Hemi's from the 60's and early 70's were cold blooded, but not a modern fuel injected Hemi.
If this may be engine related, the power train warranty could come into play.
W
Wynded12
wisconsin
Sorry about the wrong posting. Just seen 2019..lol.. I posted in 4th gen tread. So far the shop says none of this is covered under the warranty. Which is crap. Powertrain warranty has never helped me with any issues I have ever had.
MADDOG
Living in a Firepit
6.4L HEMI
No worries.
