P0300 on startup
djhartm
NC
Hello all!
I have a 2014 Limited 1500 with the 5.7L.
I have a Hemifever tune and a few other mods, but generally have seen very light duty.
Always have run Mobil 1 & changed the oil & filter long before the DIC says to.
With 53k miles on her, I began getting the P0300.
After clearing it goes away, usually for a few days, then shortly after startup, it will return.
No other symptoms.
Sean @hemifever said it could be the start of the MDS lifter failure.
I get no other specific codes (i.e. P030x).
Not sure where to begin troubleshooting.
I did a cursory check for intake leaks but found none.
Any thoughts\suggestions welcome.
Burla
Army
2010 Hemi Reg Cab 4x4
It might not be fatal, like you said it hasn't nailed down specific cylinder. I would say switch coil packs and see if it travels, but you can't because you don't have a specific cylinder reading for the mis fire yet. Keep running codes until you do.
Burla
Army
Just c&p the long possibilities. So no rough idle, I'd say you are a ways off from being able to say it is lifter/cam, but surely it is possible as we know.
  • Faulty spark plug (s)
  • Faulty ignition coil (s)
  • Clogged or faulty fuel injector (s)
  • Intake air leak
  • Fuel injectors harness is open or shorted
  • Fuel Injectors circuit poor electrical connection
  • Ignition coils harness is open or shorted
  • Ignition coils circuit poor electrical connection
  • Insufficient cylinders compression
  • Incorrect fuel pressure
H1Chester
Watching thread!
Nearly the same exact thing happening to me. Second code on start up in about a month. 2015 5.7, just hit 45k miles. No racing, highway city driving, occasional "pull". Also have the HEMIFever tune... Cleared the code and reloaded the tune. Fingers crossed.
Edit: also wanted to say that it also happened on start up. No rough idle or missing...
Tach_tech
5.7L HEMI
There was a software update for 2013-2015 DS trucks for a bunch of issues, one of them was for P0300.
D
djhartm
NC
^My 2014 had all affected updates\recalls recently applied.
H1Chester
When did this recall come out? I was not aware of another recent one. Last one I got was the tailgate latch recall. mopar.com says I'm all caught up.
I don't think it is a software issue though. I had a little rough first start this morning, no light or code. Second start leaving the store was much better and normal.
D
djhartm
NC
Mine has the same symptoms.
Occasional rough cold start & P0300 thrown, especially if sitting for a while.
No issues once warmed up or after ~10-30 seconds.
I just keep clearing it with my Trinity.
Tach_tech
5.7L HEMI
It wasn’t a recall, just a TSB. So it wouldn’t be done unless a customer came in with a problem that was covered in the TSB. It came out Feb of 2017.
D
djhartm
NC
My battery is at 12.07V sitting. I read this can cause P0300. It's the original battery - 7 yrs old.
rockyj69
