P0340 and Po344 Codes
etgainey
Melbourn Fl
My 2008 Ram Hemi 5.7 keeps giving me P0340 and P0344 codes. Ive replaced the Cam Position Sensor but its still throws the code. Any ideas would be helpful. Its also going into linp mode randomly.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
p0340
  • Low engine oil
  • Faulty Camshaft Position (CMP) Sensor
  • Camshaft Position Sensor harness is open or shorted
  • Camshaft Position Sensor circuit poor electrical connection
  • Faulty Powertrain Control Module (PCM)
  • Camshaft Tone Wheel loose/damaged or misaligned
  • Dead (Weak) battery
What are the Possible Causes of the DTC P0344 Dodge?​
NOTE: The causes shown may not be a complete list of all potential problems, and it is possible that there may be other causes.
  • Low engine oil
LoneWolf3574
If I had to guess, I'd say between the two codes, it is possible you have a wire grounding out on the cam position sensor. The feedback from GTyankee is a good starting point.
Ronsterritory
