P2196
Hvacstud
Ct
I’m looking for a little help if anyone has had this code with their diesel! 2nd trip to dealer cause of the CEL and loss of power 1st time they changed the o2 harness and the 2, o2 sensors and 35 miles same thing now they are saying contaminated fuel is causing the problem but when I said I deleted the code and the problem went away for 5-7 days they said that’s normal. Ang help is appreciated
DRkNESS
South Jersey
Sadly this is the 5th generation forum and as of yet there are no diesel trucks. Maybe ask a mod to move this to another forum ?
alpinegreenneon
Air Force
South East Wisconsin
P2196-00–O2 SENSOR 1/1 STUCK RICH
Theory of Operation
This vehicle is equipped with a 5-wire wide-band O2 Sensor. This sensor operates differently from traditional O2 Sensors. The wide-band O2 Sensor tip consists of two cells that provide different functions, a measurement chamber and a detection chamber with pumping capabilities. The oxygen pumping function is the ability to pump oxygen into or out of the measurement chamber depending on the level of oxygen in the measurement chamber. This function provides the wide-band sensing capabilities and is critical for proper oxygen measurement.
The Oxygen (O2) Sensor is used for fuel control and catalyst monitoring. The O2 Sensor measures the oxygen content of the exhaust stream. When the engine is started, the Powertrain Control Module (PCM) operates in an Open Loop mode, ignoring the O2 Sensor signal voltage while calculating the air-to-fuel ratio. The heating elements inside the O2 Sensor heats the sensor to bring it to operating conditions faster. This allows the system to enter Closed Loop earlier and the PCM to calculate the air-to-fuel ratio sooner. While the engine runs, the O2 Sensor heats up and begins to generate a voltage within a specified range. Once sufficient O2 Sensor voltage fluctuation is observed by the PCM, Closed Loop is entered. The PCM uses the O2 Sensor voltage to determine the air-to-fuel ratio. An O2 Sensor voltage that increases toward 1,000 mV indicates a rich fuel mixture. An O2 Sensor voltage that decreases toward 0 mV indicates a lean fuel mixture. The PCM makes short-term and long-term corrections to maintain stoichiometric air/fuel ratio for best catalytic converter efficiency. Short-term fuel correction is based directly on the O2 Sensor feedback and is designed for quick engine response. The long-term fuel correction compensates for variations in the engine specifications, sensor tolerances, and component aging. The PCM calculations of this feedback are designed to correct rich and lean conditions over a longer period of time. For an aged O2 Sensor, the response rate to air/fuel changes is slower than when it was new. The O2 Sensor tends to move less with the same air/fuel changes in a given time frame. Therefore, by observing the activity of voltage readings (from the O2 Sensor), the quality of the sensor can be detected.
For an aged O2 Sensor, the response rate to air/fuel changes is slower than when it was new. The O2 Sensor tends to move less with the same air/fuel changes in a given time frame. Therefore, by observing the activity of voltage readings (from the O2 Sensor), the quality of the Sensor can be detected.
•When Monitored:
With the ignition on and the engine running.
•Set Condition:
The Powertrain Control Module (PCM) detects that the O2 Sensor correction offset is too low.
Possible Causes
FUEL DELIVERY SYSTEM FAILURE
INTAKE AIR SYSTEM LEAK
EGR SYSTEM FAILURE
EXHAUST SYSTEM LEAK
OXYGEN SENSOR
POWERTRAIN CONTROL MODULE (PCM)
jlo7693
New Orleans
5.7 Liter V8 Hemi
P2196, P241A, Replaced Oxygen Sensor (B1-S1)
Complaint
The customer states the check engine light is on.
Cause
Connected a scan tool and found codes: - - 02 Sensor Signal Biased/Stuck Rich (Bank 1 Sensor 1) and P241A - O2 Sensor (Bank 1 Sensor 1) And O2 Sensor (Bank 1 Sensor 2) Concentration Mismatch. Used the scan tool to monitor the oxygen sensors with the engine at idle and at 1,500 RPM and found the oxygen sensor (B1-S1) parameter remained fixed above specifications. Used the scan tool to monitor the live misfire data at idle and at 1,500 RPM and found there were no misfire counts registered. With the engine at idle, used the scan tool to command the exhaust gas recirculation valve open while monitoring oxygen sensor (B1-S1) with a lab scope and found oxygen sensor (B1-S1) did not respond to the lean condition. Disconnected the oxygen sensor (B1-S1) harness connector for inspection and found no loose or damaged terminals. Disconnected the oxygen sensor control module, used a multi-meter to test the oxygen sensor (B1-S1) wiring harness for shorts to power or ground and found no faults, which confirmed oxygen sensor (B1-S1) was faulty.
Correction
Replaced oxygen sensor (B1-S1), cleared codes, performed a road test, and verified the vehicle operated properly. The check engine light did not illuminate and no fault codes returned.
H
Hvacstud
Ct
That is a lot of great information I really appreciate that
Raadz
