2018 Sport 1500 with OEM backup cam and 8.4 UConnect.
What camera do you recommend for the front? I was thinking this one, but where does it get its power from?:
https://www.amazon.com/dp/B07HNRYHZ6/ref=cm_sw_r_cp_api_i_3hv6Cb4D1WBXA
Do I need the VS41? Looks like the BCI-CH41 has the camera RCA so not sure if that’s the OEM backup cam I need to divert in to the VS41 module for front camera installation. Or if maybe I could even get away with the VS21 and not use the audio RCAs.
Does any wire splicing need to be done? Or does the PAC module all plug and play while the camera I referenced above just plugs in to RCA port or just tap the two trigger cables together and THATS IT? Program 1 output of PAC module to the trigger wire on camera listed above and that’s it?
Trying to avoid any fuse tap or wire splice/tapping on the OEM vehicle if possible. Debating tapping in to the cigarette lighter, but this is where I’m unsure if the trigger wire is needed for the camera because if not I’d use the trigger wire to be the 12v power supply but if not then seems like I have to fuse tap at a minimum?
Thanks!!!
