Panel where rear window switch is
RamFan2
Hey everyone...
Can someone tell me how to remove the overhead panel where the rear window switch and garage door buttons are? I think I found where that rattle is coming from so I wanna peek in there and see if I can make it stop. Thanks
300MAG
Pull down to disengage the clips, the first time is usually the hardest. I usually grab it on both sides in the middle.
Sent from my Samsung Galaxy-S3 using Tapatalk 2
R
RamFan2
Do I pull down where the plastic meets the headliner?
300MAG
Yup, just get your fingers in between the headliner and console pull down, you can pull on the corners. The first time is a b! tch. You will think it's screwed in but it's not once it breaks free just tilt it out to clear small lip on the back edge of console.
KAKA
