Parking light out when installing 7 inch evic cluster? Any help
Caprice337
Madera ca
I have a 2017 and was Swapped with a 2014 evic cluster but didn’t read my tire pressure so I traded it for a 2018 7 in evic and it says parking light out
hunterdan
SE PA
2019 classic
Do you have led bulbs in?
Bbroj
North Carolina
I have a similar issue. Just installed my 7" EVIC the other day and my 1st test drive was fine. Took the truck out today and got the parking light out message when applying the brake. It clears when I release the brake. Bulbs are stock incandescent. Both rear marker filaments work, but DO go out when the brake is applied, is this normal? Is there a programming issue similar to the fog light drop out? Thanks.
Bbroj
North Carolina
I just fixed mine! It was NOT the socket, but the wiring in the truck harness. They say a picture is worth a thousand words, so here you go! Any questions, hit me up.
