Passenger seat heater
DR Driver
2022, Ram 2500, the passenger seat heater will not turn on. I have checked the fuse, all good. Wouldn’t know what to look for in the wiring harness. Any suggestions? Thank you
Mlarv5
Crossville TN
Look at the wire harness that controls the seat heater, most likely under the seat. Pull the connectors off and check for burnt pins.
HarryS
Air Force
Clovis NM
If that doesn't work, then get a meter and check the resistance for the seat and seat back heater circuit. If open, then you have a bad heater, and it will prevent the circuit from energizing.
