PCM Replacement
Ponce Inlet
Newfoundland
Dealer says $6000 for a new PCM???
I see Flagship One online and a PCM for $700 but their reviews are hit or miss.
Can't find one anywhere in Canada.
Anyone have a suggestion?
Thanks
2012 Ram 3500 6.7
Brandon-w
Yukon
2015 Ram 1500
Thanks
2012 Ram 3500 6.7
Go to a junk yard and get one just make sure it has the same part number then use Alfa obd to program the injector codes. If Alfa can do it. If not almost any shop with a scan tool Should be able to put them in.
P
Ponce Inlet
Newfoundland
Thanks again.
Can't find a used PCM anywhere!
Are there aftermarket PCMs available?
Pull Ya
Cedar Creek, Tx
Member 'Wild one" might know of an outlet somewhere up north where you're at. If he doesn't chime in, you can PM him.
Jay
Jay
Other then the dealer,i got nothing as far as a used PCM goes Jay,lol. Personally I think his dealer is a bit whacked at the 6,000 for a new one,i'd try another dealer or one of the online Mopar retailers
P
Ponce Inlet
Newfoundland
Thanks guys. This is killing me.
Anyone know of a Canadian online retailer?
Canadian dollar worth as much as Mexican pesos right now
Troy Gillis
Alberta, Canada
Edit.. I seen you listed what your driving, I assumed a hemi.. researching now.
pacofortacos
car-part.com
several in the US, some places may ship to Canada, or if you find the correct one, maybe one of us could get it and reship it to you.
P
Ponce Inlet
Newfoundland
found a used one $700.
Truck worked fine all weekend!
Today it started barely so seems like it is the PCM.
Ricky91
