Pedal Commander ? Do I need it ?
Johnny Ram
Have a 2019 2500 Tradesman 6.4 Hemi
Read a bunch of reviews on the Pedal Commander all over the web at different places, and it sounded like a good idea and fun for a mod that wasn't terribly expensive, fairly non-intrusive and easily installed/removed, etc...
So I just wanted to post some feedback for inquiring minds that are considering it.
First thing is this truck requires a PC31. I dealt with them directly and after much discussion and emails back and forth and checking at their end, they sent me the wrong unit ... a PC78. Figured out pretty quick the plugs didn't match up ... RMA and got the right unit ... but still had to run around town to UPS, wait for the new one, etc ...
Here is the bottom line ... I don't think you need it. The stock response is actually pretty good for my needs. Didn't realize how adequate stock was until I installed this thing. The default mode when you first fire it up is "City", which supposedly tries to imitate a 1 to 1 ratio that one would experience in a conventional throttle cable set up. I have found City to be very touchy ... often I'm getting much more throttle than I expected ... has drawn comments from the old lady like "why are you driving like a maniac" even though I'm not trying to really goose it that much. So it does work as advertised ... question is do you want it ... gas tank has had a hole in it since installed, hard not to get into the pedal right now, but that will probably wear off once I'm done exploring the 36 possible settings. When I'm being "good" on the City setting and trying to drive like a normal human being, I find myself being very shy and gentle with the pedal trying to make sure I don't cause it to drop down a gear or two and take off like a bat outta' ... well you get the picture.
If you want to drive a little squirrelly and gas is not an issue, it is a fun mod ... The higher settings like Sport + have it downshifting and up on its toes with almost no throttle input ... just putting the slightest touch on the accelerator has the engine racing. For road trips or long drives when I want to be more fuel conscious, I can see value in turning it down below stock , has eco mode that really calms everything down. I'll keep it ... but not sure why.
McBroom
Denison Tx
Hemi 6.4L
Sure makes it quicker to get on the highway to safely merge with traffic. Not to forget how much more fun it adds to driving our Ram trucks
Blue Mule
bobeast
Hollister, CA
Hemi 6.4, 5.7
I love mine. One thing to note is that whatever setting you keep it on (assuming you aren't constantly changing it), your foot will eventually train itself to the setting. First impressions are often "holy crap" but after you live with it for a while, it makes other vehicles you drive feel sluggish.
Johnny Ram
Johnny Ram
I do not doubt this one bit ... probably why I'm keeping it ... I'm trying to dial into the setting I think is correct for me so I can "train my foot". Right now I'm on City +1 ... I think that's pretty close for me assuming I can learn to keep it chilled out when I want to.
What setting (s) are you using ?
bobeast
Hollister, CA
Hemi 6.4, 5.7
Mine is on sport +2 which more closely matches the Tundra I replaced.
Johnny Ram
Johnny Ram
Sure makes it quicker to 3on the highway to safely merge with traffic. Not to forget how much more fun it adds to driving our Ram trucks
Blue Mule
Agree on both counts ... just makes her even more thirsty is the counterpoint ... but yes the driving experience is more interesting !
Semper Fi Devil Dog
McBroom
Denison Tx
Hemi 6.4L
Ooorraaahhhh
Blue Mule
ToTheDarkSide
Eastern Ohio
Thank you Johnny Ram for this write up. I’ve been watching every video and reading everything that I can find on the pedal commander For the 6.4. I’ll probably get one. I don’t know why haha maybe because tuning voids warranty and I can’t leave anything alone. Now Only if this could shut Off MDS
Johnny Ram
Johnny Ram
Yeah the MDS is an issue ... love the concept but it just doesn't work properly ... I'm getting pretty good at putting it into 8th gear as soon as I start rolling, creating muscle memory as to where the gear limit controls are, ... won't have to look soon, ha ha. Let us know what you think of the Pedal Commander once you get it.
Johnny Ram
Johnny Ram
I put mine on "Sport" today and am going to leave it there and try training myself on that ... figure if you can run Sport +2 I should be able to adjust to Sport +/- 0 ... will let you know in a few weeks or something.
bobeast
Hollister, CA
Hemi 6.4, 5.7
Did you mount the pedal commander so you can access it or did you hide it and use the Bluetooth app?
The short answer is yes.
I mounted in an accessible location because the spousal unit likes it on City. I tend to use the BT app on my iPhone to change it. If only we could wire it into the Memory Seats :)
Johnny Ram
Johnny Ram
Have it temporary right now ... just hooked it up and the cable is zip ******* to keep it away from the gas pedal and my foot and the head unit is in the lowest tray below the radio ... I'm still deciding where to mount it. I did read somewhere that a guy was seeing error codes being thrown by the truck when using the blue tooth to change settings but no issues changing it manually ... but have not tested that myself. I may keep it semi-permanent in some way a little cleaner than the current install ... I think I'm just going to keep it on "Sport" +/- 0 and forget about it ... don't feel like switching it around anymore and already getting my foot trained to that setting, so maybe I will tuck it away hidden.
Puba08
Long Island
Sport+ 0 was the perfect setting for me. Mine threw a code a few weeks ago so I disconnected it for a few days. I have to say it was horrible driving without it. Got it hooked back up now and it’s how the truck should have come from factory. I have mine mounted here
Carl Grand
CHICAGO
I bought and install the PC on my 17. Best thing I ever did. I was tired of feeling the lag when giving it gas when passing people or going around them. There was like a 2 to 3 second delay in response. Now I don’t have a problem any more. City +2. I had a 09 Tundra for six years. That thing would always make your head hit the head rest when you hit the gas.
Rt71668
Long Island
I love mine ! I gradually got it to a setting I’m comfortable with. ( Sport +3 ) Well that was until a month or so ago when all of a sudden my pedal was all the way to the floor and my truck was going 20mph !!! I got a error code on my dash about throttle response and I thought my truck was done for !!! Anyway pulled off the road disconnect PC and within a min the error was gone and truck was fine. I was upset thinking I couldn’t use PC anymore had it off for a month or so and then said F it put it back on and had been fine ever since ! My mechanic told me it’s not that uncommon and can be caused by keeping it in high setting and be hard on the throttle. Sounded possible so now I keep it in sport +2
Haas
Wisconsin
Judging by what I'm reading about pedal commander, can't you basically get the same effect by just stepping on the gas pedal a little more?
rule18
Admin
NY
2017 Rebel
Not really, there's always going to be a bit of digital lag. The PC takes that away.
Reticle918
