Perform Service Light cannot be reset
Jim Perry
Wisconsin
Cummins Turbo Diesel
2011 Ram 2500 Cummins 6.7L. At 59,000 miles I changed the CCV when I was changing the turbo. Now at 70,000 miles (not 67,500) the Perform Service light comes on when I start the truck. Goes out after a few seconds, but the "i" for information stays on. I tried many time to reset it by turning the key on [both the accessory position and on with all the idiot lights on but not started position, door open and door closed -- can you tell I search the forum for answer already???) -- depressed brake pedal 2X (both slowly and quickly) and then depressed accelerator to floor twice, both slowly and quickly, turned the key off] AND THE DAMN LIGHT STILL COMES ON when I start the truck.
I'm sure the dealer would want $500 to reset the light ...
HELP!
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
I thought you had to turn the key to the on position
At least that's the way I do it
Knice12
